Wire labels moving out of position
It's worth a shot. I'm to the point where I'll try anything. I'll update the thread once I'm done and have tested it a few times. Thanks again
Message 11 of 12
(255 Views)
If you have VI Scripting active, you can write code to query the size and position of the BD of a VI. The code would look something like this:
This is no complete VI since it leaks the references to diagram and VI.
Here you find a KB about the maximum size of front panel and block diagram in LV.
Norbert
Norbert
Expert: Geometry
Message 12 of 12
(249 Views)
