Write 3d array to tdms file
Hi, im trying to create a new tdms file to write data, I dont know how to do it, its a 2d array and after the for loops its 3d. I tried to change it to last value or concatening but only writes 1 row, I think im loosing part of the data.
Thanks.
(851 Views)
Hi Daniel,
You may write separate signals/groups inside the FOR loop, setting all scalar values as properties for the "Part" data block.
Or you could concatenate the "Part" data at the loop border to a larger 2D array…
(844 Views)
Hi GerdW,
I tried to concatenate, but when I do this, the TDSM file have a lot of channels created, and I dont really know if its good, I never used before TDSM files. And I dont know what do you mean by writing separate signals/groups in the for loop.
What I'm doing know, only to can test this is concatenating, indexing the array in 3 1D arrays (In theory, the "Part" data are 3 values (X, Y, Z) and then building it again in a 2D array. But I dont think this is ok.
Thanks.
(789 Views)
Hi Daniel,
As long as you only attach images of small parts of the block diagram of your VI we cannot assist with code fixing…
Well, you are the one who can debug that code. We cannot debug/edit/run images with LabVIEW…
(779 Views)
