XControl - Item Settings strange behavior
I am developing an XControl and I ran into a strange problem. If I create an property and go to XControl Properties -> Item Settings and select Property, I am able to set Unique identifier, description, etc. But when I close the project and open it again and go to Item Settings the Property is not marked as property anymore (it appears as normal folder), thus I am not able to set Unique identifier, description, etc. anymore. I attached the two images below that demonstrates the behavior. Tried that several time and it is always the same, also when I create new XControl. I have LV 2012.
Normal behavior
After the project was closed and opened again
Andrej
(2,233 Views)
Accepted by topic author andrej
Dear Andrej!
Thank you for the detailed description. I've checked, and this is a known issue with LabVIEW currently.
To work around this problem, you can open the XControl directly with LabVIEW (so just opening it as is, and not as part of a project).  This enables you see and specify all Item Settings correctly.
Kind regards:
Andrew Valko
National Instruments AE
Andrew Valko
National Instruments Hungary
(2,214 Views)
Thanks Andrew, this works!
(2,209 Views)
