XPS (XML Paper Specification) Reader
@PatrickLye wrote:
In Explorer it only shows one file
After extraction it only shows one file
Yeah, now extract that file Smiley Wink
The forums blocked attaching just the XPS file so to get around this I attached a zip that contained the one XPS file.  Since doing that I learned that XPS is just a fancy zip anyway.  So if you open the XPS file in 7-zip it will treat it as an archive file and show everything inside it.  Alternativly you could rename the .XPS file into a .zip and then Windows will gladly show the contents of it.
Message 11 of 11
(855 Views)
