XY-Graph / Plot legend: How to detect changes in 2nd/3rd/4th ... legend position
I have an XY-Graph with 4 plots. How can I detect, for example, the color change of the second plot in the legend. The active plot, using a property node, is always plot 0. So I am not able to detect changes in the 2nd/3rd ... plot.
Any ideas?
Thanks a lot.
Michael
(2,963 Views)
Hi Michael,
you might write into the ActivePlot property to select which plot you're accessing...
(2,954 Views)
Hi GerdW,
thank you. But I want to detect the active plot by clicking on the coresponding icon in the plot legend. If I read the active plot via property node, the value is always 0. Regardless which icon in the plot legend was clicked.
Michael
(2,950 Views)
Clicking the plot legend doesn't change the active plot. You have to set that property programmatically...
(2,948 Views)
Ok. Thanks a lot.
Is there a work around or trick to get the information which position on the plot legend was clicked to set the active plot programmatically?
Michael
(2,939 Views)
Accepted by MichaGue_01
You can do it with an event sturcture.
(2,929 Views)
Hello MStewart,
Could you please upload plot detect VI in 2011 labview Code please.
Many thanks
Lazer
(2,866 Views)
