about VISA write value
I want to write a freuquency value into VISA write buffer. but the integer part and fractional part should be written in different registers.
this is what I've done:
but the array cannot connect with the VISA string. How can I change the configure? Thanks!
(3,009 Views)
you should write to each register one by one.
VISA write does not accept clusters.
(3,005 Views)
That is not an Array, but a cluster that you are sending to VISA Write.
(2,972 Views)
I think what you really want is Concatinate Strings.
GCentral
(2,965 Views)
but after combining them by using concatenate string, the string becomes 64bits, isn't it?
(2,911 Views)
No, it just becomes a longer string. The number of bits is only a factor for a number that is being expressed as a single binary value. You are creating two commands that each consume 4 bytes. Concatenating them will produce a single string 8 bytes long.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,895 Views)
Just a fair warning.  A lot of instruments do not like to recieve commands back-to-back like this.  You may need to use two VISA Writes (one for each command) with a small delay in between to allow the device to process each one.
GCentral
(2,872 Views)
