ado stored query
Hi
Im using the ado toolkit, its works fine. NBut i have a problem. I read the stored querys in my acces database. But i also want to use those querys. How do i do this? Can I read the SQL code of the stored query or is there an other option or is t impossible.
Bart
Labview CLD , Engineer/Manager
Promedes and DSM
using LV 7.1, 8.0, 8.2, 8.5 and 2009 SP1
http://www.promedes.nl
(3,024 Views)
You can use the queries in MS Access as you would any other table e.g. SELECT qryTestDist1.* FROM qryTestDist1; where qryTestDist1 is a saved query.
Does that help?
Daviid
(3,018 Views)
is qryTestDist1 the name of the saved query?
Promedes and DSM
(3,016 Views)
Yes. E.g. I am working in Access and created a query using the query builder and saved it as qryTestDist1 in the Queries tab. Make sense?
(3,014 Views)
dus how exactly does my query string should look like if my query is called "test"
Promedes and DSM
(3,012 Views)
SELECT * FROM test;
(3,009 Views)
