07-25-2011 05:50 AM
I need to collect data and later analysed them in labview signal express. I could do as i get thee data but saving the project and doing the analysis later is not working using the add step function.
What should I do ?
Secondly how do you convert to ascii and export to excel or word when using signal express ?
Matthew
07-26-2011 12:08 AM
Hi mathade,
I am not sure what exactly are you trying to do. Are you taking some signals from signal express and then saving them and later reading the saved values for analysis? If this is what you want to do, you can simple write your values into a spreadsheet and later on read it from there using the File I/O functions for doing the further analysis. If you want to do it in the same execution run, you can also hold the values in some shift registers and get the analysis done after the acquisition.
I can give you more information if you can post your vi so that I can take a look at your progress so far.
Nitzz
(Kudos are always Welcome;))
07-27-2011 04:39 AM
Thanks Kudo for your reply.
The problem is that the signal acquired cannot be exported to excel or word and taking about I/O, I really don,t know what that is. I am completely new to signal express.
Matthade
