07-13-2016 12:37 PM
I'm new to Labview with a lot of help from people here I've managed to make this VI which logs 34401 DMM measurements to a file. I noticed in the file IO functions there is Data Storage and was wondering...
1. if it can be used to store the data from the DMM?
2. Does the TDM store the data as the data is writen to it or does it only store the data once you close the file?
I'm asking the second question because my current vi, see attached, seems to only write the data once the file gets closed which has consequences if I plan to collect days or weeks of data
07-13-2016
12:54 PM
- last edited on
08-12-2024
01:35 PM
by
Content Cleaner
This should get you started:
https://www.ni.com/en/support/documentation/supplemental/06/the-ni-tdms-file-format.html
07-13-2016
04:14 PM
- last edited on
08-12-2024
01:35 PM
by
Content Cleaner
