arduino
How Do I Setup the LabVIEW Interface for Arduino to use an ethernet connection. Please help. Thanks.
Message 1 of 14
(4,795 Views)
Do you know how to connect to the dropbox, the link don't work. Thanks.
Message 3 of 14
(4,777 Views)
The last link in that thread works.
Message 4 of 14
(4,774 Views)
 I can get link this time. Thanks
Message 5 of 14
(4,769 Views)
I already installed the LINX. So can the 'LIFA-Ethernet.zip' work with LINX? Whereis best place to put this fold? Thanks
Message 6 of 14
(4,752 Views)
From what I know, LINX is a replacement for LIFA. You can only install one sketch.
Message 7 of 14
(4,736 Views)
Yes LINX is supposed to replace LIFA.  I'm not totally sold on it but I see the improvements with other hardware support.
In any case the Arduino can only be running one program at a time.  So yes you either choose LIFA, or you choose LINX.  You can also write your own communication scheme, or modify LINX/LIFA for your needs.  They are both open to modifications.
Message 8 of 14
(4,664 Views)
Thanks for response, I don't have idear how to modify. Is possible using multiple arduino (will using more than 10 ) interface to a VI?
Message 9 of 14
(4,639 Views)
You should post your question to the LINX community board.
Message 10 of 14
(4,628 Views)
