binary data into bitmap image
hii Mr jorn.. may i know how to use Draw flatten Pixmap..Pls post an simple example..
i think this is for my problem which i m facing..
thanks
thanks
do not hesitate to give kudosSmiley Happy
Message 11 of 19
(2,613 Views)
thanks
Message 12 of 19
(2,612 Views)
Hi Sahil
Let this be our secrets do not tell anybody else;) Labview has something called context help. You enable it by typing Ctrl+h. After you have done this you will get info about any Labview function just by putting the cursor over it. Your secret portal to more help is something called "detailed help" in the help windows. Here you will find cheats like ready to run examples. Another source for ready to run examples is to go to help in the toolbar and then select "Find examples" here you will find a way to search in examples
But remember do not tell anybody about this futures
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 13 of 19
(2,600 Views)
hii rogue..
thanks for the suggestion..
but i was hoping for the good answers...
thanks again...
thanks
Message 14 of 19
(2,582 Views)
Hi sahil,
"Draw flattened pixmap" simply takes the image data from the picture file read functions (like "Read BMP file" and makes a picture indicator from it. What more examples do you need?
It would also help to give the important information in the first place, like "I have a BMP formatted picture...." Smiley Wink
Message 15 of 19
(2,579 Views)
Hi there. I have my binary data inside .csv file. Can you please tell how can i decode the image from this data.
Message 16 of 19
(1,735 Views)
Hi verma,
In a csv file you usually have readable text!
To convert your "binary data inside csv file" you need to know the format of your data. Then you read the file and parse the data as required for that format...
Message 17 of 19
(1,733 Views)
Accepted by rolfk
Can you send this code if you still have it ?
Message 18 of 19
(1,465 Views)
That was a long time ago
Message 19 of 19
(592 Views)
