binary image to color jpeg
I am manipulating (B/W) ICCD images with Vision.  Unfortunately, I have to cut the images down to I8, but that is not the issue.  My question is this-  Labview allows me to visualize the I8 data with a "rainbow" color map.  I would like to get it to automatically create a color JPEG file (or other image file type) that I can open in powerpoint.  I am aware of the IMAQ write file2.vi, but that only writes a grayscale file.  How do I go about interpreting the I8 values to color data?  Sorry, I am a newbie to image manipulation.  J
(2,893 Views)
Use something like this.  Fill in the array constant with the colors that you want.
(2,883 Views)
I'm using labview 11.0 (sorry, I know that I am supposed to include this in my post).  Could you save the vi for an earlier version or post a picture of the back panel?  Thanks.  J
(2,875 Views)
(2,851 Views)
Thanks. Are you aware of any way to programmatically fill in the color array?  The IMAQ getpallete.vi doesn't seem to do it.  J
(2,835 Views)
Sure.  You can create the array programatically.  How you would code it depends upon what you want the array to be.
You would probably make use of this:  Functions -> Programming -> Graphics and Sound -> Picture Functions -> RGB to Color.vi
(2,811 Views)
