build 32 bit installer in labview 2010 64 bit
I have built an installer file using Labview 2010 64 bit.  When trying to install on XP 32 bit I get an error saying the installer is only contains 64 bit installation files.
Is there a way to create 32 bit installer packages using Labview 64 bit?
Cheers,
Tom
(3,526 Views)
Accepted by teeeeg
Hello Tom,
Unfortunatelly you can't build 32-bit installer on 64-bit LabVIEW.
However, if you can download and install 32-bit LabVIEW on the same computer. You can download it from our site PRODUCTS with same serial number as you already have from 64-bit version.
Best Regards,
Gregor Černe
(3,515 Views)
in order to build a 32-bit installer you need to have 32-bit LabVIEW installed.
Daniel
Dániel Fülöp
Field Application Engineer (CLA, CTA)
(3,512 Views)
Thank for the info guys
(3,482 Views)
Is this still true for LabVIEW 2013? and If you have LabVIEW 32 bit, will an installer you build work on a 64 bit machine?
(3,121 Views)
It will be true forever, as this is a Windows architecture thing.  You can install a LV 32-bit installation package just the same way you can install just about any 32-bit application on an x64 Windows machine.
Bill
CLD
(Mid-Level minion.)
(3,110 Views)
