cRIO-9048 via RS-485 to Oriental Motor Driver
Hi All,
I am trying to control a Oriental Motor through LabVIEW using a cRIO over RS-485.
cRIO: cRio-9048
Comms: RS-485
Motor driver: Oriental Motor RKS5D507-CD
Motor: PKE566MC
The driver uses RS-485 2 wire connection. I have made the necessary changes as per https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGwxCAG&l=nl-NL.
I am using the example "RS-485 Transceiver Control.vi" from the LabVIEW help resourses.
I already have operational data on the driver.
When sending the start command as stated in the manual: "01 06 00 7D 00 08 18 14". I get a timeout message:
And from the driver side I get this error:
Now I have checked the connection.
I have no idea on how to get messages through to the driver.
Any assistance will be greatly appreciated.
Thank you in advance
(163 Views)
Just to make sure you don't make a mistake in the wiring (which I did), are you using RJ50 or RJ45 on the RS-422 port? A RJ45 connector will fit into the RJ50 port but won't have the connection.
(132 Views)
