07-09-2020 02:37 PM
All
I am trying to synchronize my cRIO to a NTP server that is hosted on an accessible intranet but no access to internet. I was looking at
I was going to download the opkg package offline from https://downloads.openwrt.org/releases/, and transfer via USB to the cRIO and install.
It looks like opkg is target dependent. It looks like cRIO 9045 is armv7, but how do I match that with the compatible targets for opkg? Thoughts?
07-10-2020 04:19 PM
There are feeds which have a lot of standard packages compiled for Linux RT systems at http://download.ni.com/ni-linux-rt/feeds/ .
Also, I believe the 9045 is x64 and not arm.
07-10-2020 05:22 PM
I ended up following these 2 links and it solved my issue 🙂
Above link specifically addresses synchronizing cRIO to NTP when there is no internet available
https://www.cyberciti.biz/faq/linux-unix-bsd-is-ntp-client-working/
tells how to verify
(this is good for people who are not linux savvy)
06-15-2021 07:53 AM
Thanks for sharing your insight. I'm also facing the issue how to update a cRIO without internet connection and with limited linux skills. Unfortunately the slideshare link is not working anymore. Probably it's just a few lines of shell commands, right?
06-15-2021 08:32 AM
PDF copy of the slides attached.
07-15-2023 03:31 AM
I am capable to make offline installation of a cRIO Linux Real Time system.
When I am connected with ssh, I can use opkg update and I can see that opkg uses my PC as a server.
But now I want to install NTP and I cannot find a way to download the ntp packages from openwrt.
Where did you find your ntp packages and how did you dowload them ?
Thanks for your help.
