calculate the energy of a signal
Thanks a lot Martin ... i will check it right now 🙂
Message 11 of 17
(1,878 Views)
Hello Martin,
I couldn't open the file since the files I have are .txt !
Message 12 of 17
(1,875 Views)
Hi Imano,
there is only filter for lvm files, you can switch to see all files and select the txt file too.
Martin
Message 13 of 17
(1,871 Views)
Hi Martin,
there is a problem when opening the file ... when I choose the file and run the program the menu come automatically and I can't stop the program ... I didn't understand what you mean by lvm filter ? ... and how can I plot the variation of energyy in terms of time for each signal since by project is studying the muscle fatigue and this can be known when the energy is getting increased with time
Thank you
Message 14 of 17
(1,867 Views)
Accepted by Imano88
Hi Imano,
if you doubleclick on Read From Measurement File, you can uncheck "Ask user to choose file", so VI will use filename you wrote to the top of this window.
By the lvm filter I meant the setting in file dialog when VI asks you for selecting the file. It is the small select list on the right bottom side. I attach also the screenshot.
You can show she signal in time domain using the VI I modified from previous one. About energy values -- you can connect these values to Waveform Graph to see it. Otherwise I probably do not understand exactly what trend you want to show and how. I can help you how to implement it but you have to have clear requirement otherwise I can only guess what you are trying to do.
Martin
Message 15 of 17
(1,847 Views)
Thank You 🙂
Message 16 of 17
(1,838 Views)
Good morning,
Please i want to calculte the energy by labview of a signal received with ni usrp
help me
Message 17 of 17
(1,674 Views)
