changeto chart x axis unit
ok. So which input control in your vi determines the X-axis values? is it predefined or dynamically variable?
Message 11 of 28
(1,399 Views)
I want to control x axis value.This value is dynamically variable and coming from encoder every 15 c.meter. X axis and Y axis must be synchronization with my datas.
Message 12 of 28
(1,393 Views)
Accepted by kacco
Hi kacco,
"my datas coming from fpga every 15 centimeter."
So you get one value every 15cm? If so simply change the x-scale multiplier to 0.15 and use "distance [m]" as axis label.
Again: you don't have a "default unit"! You have some default axis labels. This is quite different...
Message 13 of 28
(1,392 Views)
I dont know if i understood the exact requirement of urs, but kindly check the below attached VI
Message 14 of 28
(1,383 Views)
thank u for every one about my problem.Solved this problem.I didnt understand what is the meaning of x scale mutli(propertynode) ? And why multiply 0.15 ?
thank you for again
Message 15 of 28
(1,380 Views)
Hi Krunal,
using a waveform is ok too - with using 0.15 as dt value the requirement is fulfilled too.
Hint: save some default values in the array before posting as an example vi...
Message 16 of 28
(1,377 Views)
Hi kacco,
have you read the context help?
You can customize each axis to your coordinate system by using an offset and a multiplier (shift and distort).
The 0.15 should be obvious here: your data are spaced with 15cm - which is 0.15m and I suggested a label of "[m]"...
Message 17 of 28
(1,374 Views)
Hi ,
I get a continous streaming data from cRIO  module ethernet port.
The variables coming from cRIO are shared variable.
My variables are:
no of pulses (distance in mm) determined from an encoder - for x axis
a sensor output during each  - for y axis
PS: Please notice encoder speed may vary - so the no of pulses per time interval which means distance data is asynchronous.
I want to show sensor output data with respect to distance in mm.
ie:
x axis - encoder counter in mm:   0 2 5 7 8 15 ...etc
y axis - sensor output:                 5 6 6 5 4 3   ... etc
I will appretiate if anyone could help me to display the data in real time on a chart or graph
Kind Regards
Message 18 of 28
(1,324 Views)
Hi kacco,
use an XY-graph...
Before you always said your data is evenly spaced - atleast that was my impression!
Message Edited by GerdW on 11-05-2009 07:16 PM
Message 19 of 28
(1,318 Views)
hi,
ı use to xy graph but xy graph doesnt work with my codes.I dindt show my plots with xy graph you can send a simple xy graph  example with while loop searched and tried all labview example.
Message 20 of 28
(1,305 Views)
