chart update rate
I would like to create a vi containing a while loop, however I want charts data to be updated every second. Which is the proper way to do it so?
Thank you in advance
(4,291 Views)
You can make 2 states, wait and update. In wait state, you can put 1 sec delay and in update mode you can update chart.
I think this is the simple way. You can have another loop acquiring/generating data which you want to display on the chart.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(4,287 Views)
Hello gak,
Thank you for your reply. Could you please be more specific or attach an example vi.
Best regards
(4,278 Views)
Accepted by LW42
I'm not sure to understand what you mean...
Is your while loop acquiring/generating data at more than 1Hz?
If yes, I assume you want to update the chart only each 10 or 100 loop iteration.
Here is a quick example (documented in LV 8.6).
Hope it help
Epictetus
Antoine Chalons
(4,273 Views)
Dear Titou,
Thank you very much for your suggestion.
Best regards
(4,258 Views)
