check serial port availability
I would like to check is a serial port availble (not already opened by another application) without opening and closing the port.  Currently, the program opens and closes the serial port a lot.   Sometimes, an port access deny error occurs.  We suspect that after a the close command is issued, the port didn't close immediately and another application try to acces the port at the time, which generated the error.  Any idea?
Kudos and Accepted as Solution are welcome!
(3,977 Views)
You might want to ask yourself why your program opens and closes the serial port a lot.
You should open the serial port once at the beginning of your program, pass the VISA reference throughout, then close it once at the end of your program
=== Engineer Ambiguously ===
(3,962 Views)
Agree with suggestion to ask yourself why the port is closing and opening so much. That is going to a cause a lot of confusion.
If you still want to close and open it a lot, look at the error you get when trying to open the port. Error -1073807246 tells you that the VISA resource is valid, but it can't be accessed. That is a pretty good indicator that the port is in use somewhere else.
(3,942 Views)
opening, pining, and closing is for searching through all the existing comm port to see which port I am communicating on.
(3,854 Views)
The opening and closing is due by a custom .net DLL function.
(3,852 Views)
As already mentioned, you have to attempt to open the port and check the error returned.
(3,834 Views)
Well without any code to look at I have two suggestions...
1. Dump the DLL and either use LabVIEW to search for the port the device is on or just tell LabVIEW what port to use.
2. Put a delay in your program every time the DLL is called to make sure it is done with the ports before LabVIEW tries to access it.
(3,820 Views)
