colorbox grayscale
I need to control a colorbox indicator with values from 0 to 225, but the colors must be in 8-bit grayscale.
Any ideas?
Message 1 of 11
(3,540 Views)
Accepted by žabić
The color box is U32. Given a U8 greyscale number, you simply need to join it three times, and pad with zeroes to get a greyscale color value.
There is the RGB to color tool that does this for you. Simply wire the U8 value to all three inputs.
Message 2 of 11
(3,537 Views)
is there a way to separately control background color of each element in an 2D array indicator?
Message 3 of 11
(3,516 Views)
No, elements of an array can only differ in value, they cannot differ by properties (such as background color).
Message 4 of 11
(3,514 Views)
You can create a cluster of a transparent numeric in front of a color box, and create an array of such clusters. For a colorbox, the color is the value, so that will work.
Message 5 of 11
(3,513 Views)
okay, tnx
Message 6 of 11
(3,508 Views)
could you send an example...i cant get i to work
Message 7 of 11
(3,491 Views)
What is your LabVIEW version?
Message 8 of 11
(3,484 Views)
Try something like this (LabVIEW 8.2). modify as needed.
This is using flat classic controls for the inner elements for simplicity. ("Color Box" and "Simple Numeric" from the classic numeric palette)
Message 9 of 11
(3,480 Views)
Another option is the use of a table instead.
Here you have full control over the background color of each cell. That's what I typically use.
Message 10 of 11
(3,473 Views)
