colour in numeric array indicator cell according to value
Is it possible to change the colour of the text in individual cells of a numeric display indicator dependent on the value of the numeric displayed in that cell.
Message 1 of 8
(3,516 Views)
I am not sure if i understand your question. Do you want to color each DIGIT of a single numeric indicator individually depending on the digits value?
Or are you talking about different numeric indicators where all digits share the same color for each individual indicator depending on the total value in the individual indicator?
Norbert
Norbert
Expert: Geometry
Message 2 of 8
(3,514 Views)
Ignore.
Message 3 of 8
(3,513 Views)
I assume that the subject of your thread is part of the question, i.e. you have an array of numerics and you do want to change the colour of an individual array element (depending on its value).
That is not possible, all elements of an array do share the same properties.
Regards, Jens
Kudos are welcome...
Message 4 of 8
(3,505 Views)
The colour of all in the text in a cell would be the same, but the colour of the text in a cell would change accordiung to inte numeric value. For example:
                < -40 : RED
        -40 to -20  : ORANGE
       -20 to +30 : GREEN
      +30 to +60 : ORANGE
              > +60 : RED
Then dependent of the numeric values of each cell, some cells would have text or background RED, some would be ORANGE and some would be GREEN
Message 5 of 8
(3,490 Views)
Accepted by IanLuck
You can use list box instead of array indicators. You can change each cell property individually.
Message 6 of 8
(3,481 Views)
You could also use an array of clusters. Each cluster would contain a string indicator made transparent and a color box indicator behind the string indicator. You write the text to the string indicator and the color to the color box indicator.
Be aware that if any of your users are color blind they will find black text on a red background very difficult to read.
Lynn
Message 7 of 8
(3,474 Views)
Thanks for the suggestion.
With the multicolun list box, I can colour the individual cells just as I wish.
Message 8 of 8
(3,462 Views)
