comma separator for large numbers, how to?
A question that I always have with .NET... How does one find the correct constructor (in this case, where is "StringBuilder" in the drop down list? Thanks.
Message 21 of 26
(1,011 Views)
you can drag yamaeda's  2011 snippet onto your blockdiagram to spawn the LabView Code,
and then right click the first .net constructor > select constructor :
Message 22 of 26
(983 Views)
Yeah, that's always a mess. You search for it on MSDN and find the namespace, if memory serves, and that's what you should use in LV. Or if if was the DLL that holds the namespace ...
Qestit Systems
Certified-LabVIEW-Developer
Message 23 of 26
(960 Views)
I needed this, so I made it.
Message 24 of 26
(618 Views)
People can (could) set other separators, so it's better if you read them from the register instead.
Qestit Systems
Message 25 of 26
(601 Views)
Good point.  Here's the upgrade.
Message 26 of 26
(568 Views)
