12-12-2016 03:58 AM
hello guys,
i'm ramdani,
i'm using labview 2014,
i have uploaded two video,
in the video cont sound input, 1 signal per sample
the signal is not continues, as you can see,
( i have used chart-update mode too, but no result)
in the video soundd file to sound output,
the signal is contionus,
so, i want make contionues signal in cont.sound input file,
how can i make it ???
12-13-2016 07:01 AM
You get a much bigger chance for relevant help if you attach your VI(s)...
12-13-2016 07:17 AM
And be sure to attach VIs, that is, files with the extension .vi. If you attach a picture of part of your Block Diagram, this will not be that helpful to us in trying to help you.
12-14-2016 12:54 PM
sorry, i forgot to attact the file,
i using the example file in labview 2014 that i modified,
here's the file 🙂
