controlling a stepper motor using labview
what components do i require to control a stepper motor using labview?
Alsi i have a ni-usb-4431 daq box. Will that be of any help?
(3,073 Views)
You can use NI PCI/PXI 73XX motion cards and a drive to control/move your stepper motor.
What is the Stepper motor make..?
USB 4431 is DSA module and it wil not help in controlling stepper motor.
Bijay
(3,061 Views)
thank u bijay
ok so now correct me if i'm wrong:
the flow will be
Labview code --> NI PXI/PCI-73xx motion controllers (connected to computer ) --> stepper motor drive --> stepper
any other component required?
also this is for a project in which i am required to make a sort of robotic arm for moving things underwater to exact locations (x, y and z coordinates specified) using stepper motors. LabVIEW has to be used to control the motors.
(3,055 Views)
Accepted by topic author aks23
If its computer then,
Hardware : PC >> PCI Motion Card >> UMI - 7774 >> Motor Drives >> Stepper Motor.
Software: LabVIEW.
Better you can consult with an NI engineer . They can guide you better.
Bijay
(3,048 Views)
