11-25-2009 01:25 AM
11-25-2009 02:02 AM
11-25-2009 05:59 AM
atmcd32d.lib
11-25-2009 06:00 AM
11-25-2009 06:06 AM
11-25-2009 07:25 AM
malavi,
If you have LV8.0, then you could save it yourself to the previous version which is LV7.1.
I totally agree with Gerd. You should avoid the Stacked Sequence Structures and the mild abuse of Local Variables. They will be your worst nightmare in the future. Or worse... They will be someone else's worst nightmarein the future.
I would suggest a State Machine. Much cleaner, no Local Variable & no Stacked Sequence.
Do a search on State Machines. There are hundreds of examples.
To learn more about LabVIEW, I suggest you try looking at some of these tutorials.
11-25-2009 11:03 AM
11-25-2009 11:48 AM
malavi wrote:
I got the above program from the device provider.
Yikes!
You
You mean that some company provided that code as a driver? If that's the case, they need help 😉
If it was from a buddy, then okay... we'll fogive him LOL!! 😄
Yes, if you need help, please use this forum. It's great. Also visit to improve your programming skills in LabVIEW.
11-28-2009 12:57 AM
11-29-2009 10:20 PM
