convert lv5.0 vi t0 lv8.5 please
I found this vi from ni.com. But it is in version 5.0. Could you please convert them to version 8.5.
Liming
(2,545 Views)
Here they are as a 8.2...
But I would look into the daqmx VIs they can read a thermocouple directly to a temperature
Ton
My LabVIEW Ideas
(2,541 Views)
I try hard to make it work, but failed.
here is what i have. can you tell me how to use daqmx vis.
(2,526 Views)
here are two vis i found, but I do not feel they are the right one for SCXI-1102 thermcouple. If you can supply one, i will be very happy. They want do temperature tomorrow, I still can not make it work by now.
Liming
(2,522 Views)
Hi Limey,
What is it that you are trying to do with your SCXI-1102 module? Acquire and graph?
If that's the case then you should open the Cont Acq Thermistor Samples-Int Clk-SCXI 1102+1581.vi
then modify it by changing the DAQmx Create Channel Polymorphic VI to the AI Temp TC setting.
Finally make sure that you delete the additional thermistor related controls and add in the appropriate thermocouple ones.
Message Edited by Jordan D on 09-13-2007 10:27 AM
Jordan D
Applications Engineering
(2,485 Views)
