12-10-2019 05:51 AM
how to convert .sql file to .udl file.
for using the database connection toolkit.
as the input for dbct is connection information which should be a .udl file.
please help me.
thanks...
12-10-2019 08:59 AM
A .udl file is used for storing connection information. A .sql file is typically SQL code or queries that you wish to save to disk. Both are text files but are not really used in the same manner. So I don't fully understand your question.
You can create a file on the desktop with a udl extension, double click the file and use the Data Link Properties box to establish a connection. Then you can open the udl file with a text editor to grab the connection string. Maybe this is useful for you. If not, please explain your question.
12-11-2019 12:02 AM
ok thanks...
I got another error
please try to solve it.
12-11-2019 06:24 AM
You are using the wrong driver to connect to the database. Did you use the UDL file and data link dialog box to test the connection?
12-11-2019 07:48 AM
thanks for helping me.
now I used the correct driver to connect the database.
