copy data from many files to one file
If I have around 100 files. Every file is an array in 1 D contains 1 column with 1000 lines (numbers).
I want to copy the contents of these 100 files and paste them in only one file. I want the new file also array 1D.
If I do it manually, it will copy the input files contents and paste it in the new file.txt one by one Down each other.
i tried to do something like the attached but till not give the expected results.
(2,173 Views)
Hi Baja,
Simplified your VI:
Why do you work with 2D arrays in the loop when you need just 1D arrays?
(When you need to know the name of a function you should have the context help window open. No need to clutter a block diagram just to show the name of each and every function…)
(2,156 Views)
Accepted by BaJa_2020
Do you have an example file you could share?  Why not just read the entire file as a string and just write that to the new file?
GCentral
(2,148 Views)
this is example of the input files
(2,143 Views)
Hi Baja,
Where?
(Please ZIP files before attaching.)
(2,135 Views)
Any way your way is working, I accept it as solution,, Thank you
(2,133 Views)
