count and filter number of occurrences of string in an array
Hi.... I need filter and count display for number of strings occur in a single column of string array...I can't explain....below I just represented what is my need.  Column A is Input string array...Column B and C are the output arrays....
Column A          Column B            Column C
Apple                  Apple                         3
Banana              Mango                        2
Mango                Banana                      1
Apple
Apple
Mango
Can anyone help me...?
Message 1 of 11
(6,750 Views)
If you cant explain then how can you expect answer....
Here I attached sample vi which will help you to some extent. Let me know if  you need any help
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 11
(6,741 Views)
I would use variant attributes. The key will be the name and the data will be your count, with a default value of zero. Do "get variant attribute, increase the count, then set variant attribute
Message 3 of 11
(6,732 Views)
Accepted by azadplc007
Here, I drew up a quick example of what I mentioned above.
Message 4 of 11
(6,720 Views)
ya its working... but,I need output data are sorted manner.... from max to min......
Message 5 of 11
(6,686 Views)
Use sort 1D array.
--Ranjeet
Message 6 of 11
(6,678 Views)
Use index and bundle cluster array. Then sort. Then reverse the output array.
When you sort an array of clusters, it sorts by the first element. That is why you can do this because the numbers get sorted, and the name comes along for the ride. But this will sort least to greatest, so the reverse of the array makes it greatest to least.
Message 7 of 11
(6,663 Views)
Actually, Ranjeet, there is value to asking an unformed question.  People can then ask more questions to help the user define their problem.  In fact, that's the way it happens in I'd say a majority of posts here.
Bill
CLD
(Mid-Level minion.)
Message 8 of 11
(6,654 Views)
In fact, I think the example given did a fine job of explaining, even though the words may not have. Sometimes I wish more people would post inputs and desired output, so I don't have to try and interpret what they are saying in the first place. Often times the more words there are just increase the chances of saying something contradictory when trying to explain the problem which leaves us at square one.
Message 9 of 11
(6,646 Views)
Ranjith...
I wanna say onething.....each and every people are not well qualified in all fields.... If you know one thing, I might don’t know about that....If I know something, you may not know about that... helping is always good habit.... anyway Thanks for your replying....
Message 10 of 11
(6,621 Views)
