creat 2d array with 2 cluster
hello every one,
I have a problem,
I want to create a 2D array who display my 2 cluster of my CAN protocol
I give you my program and I use PCAN drivers in my program
drivers :
https://lavag.org/topic/15784-cr-pcan-driver_lv2009/#comment-95558
Message 1 of 14
(273 Views)
Hi letesego,
@letesego wrote:
I have a problem,
Which problem do you have?
Which 2 clusters do you want to process?
Why should there be a 2D array (for display purposes)?
Can you provide a simplified VI with just those 2 clusters and the expected resulting array?
Message 2 of 14
(267 Views)
Hi GerdW
I want to create 2D array indicator who included my data in my 2 cluster so read and write output
the goal it's when a new data was read or write, the data was integrate in the array.
I hope you understand my problem
letesego
Message 3 of 14
(256 Views)
Message 4 of 14
(252 Views)
Hi letesego,
The image in message #4 helped more than your text…
Suggestion:
Message 5 of 14
(249 Views)
Spoiler
that not solve my problem I want add the new data in a other column and keep the old data
sorry if my english isn't good
letesego
Message 6 of 14
(240 Views)
Hi letesego,
Please define how to "add new data to a different column": how should the result look like?
My example keeps ALL data, regardless of "new" or "old", so please again: define how the result should look like!
Btw. there's no need to hide your message in a spoiler tag…
Message 7 of 14
(224 Views)
Message 8 of 14
(217 Views)
Accepted by topic author letesego
Hi letesego,
so you want to place ONLY the data arrays of write/read CAN cluster into your 2D array!?
Why don't you write so?
Simple solution:
  • Unbundle the data arrays from both CAN clusters.
  • Concatenate both 1D arrays into a larger 1D array.
  • Autoindex the 1D array at the loop border into your 2D array…
Message 9 of 14
(206 Views)
Hi GerdW
That was my best try but that not work
I'm testing many thing like use for loop
I think I haven't a good used with array
Could you help me a last time ?
Best regards
letesego
Message 10 of 14
(143 Views)
