creating 1-D array of type double
I am not that good with the labview and when I was trying to build some example I got a error as in the attached image.
Can some help me in creating a simple 1-d array of type double in labview2011.
Thanks.
(4,636 Views)
You are trying to connect a 1D array with a double value.
Basicly you are connecting a table from 1x? to a single value.
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
(4,632 Views)
Your array is fine.
The wiring error lets you know that you've wired an array into a sink that expects a scalar.
Are you trying to operate on the array or on the scalar?
You may need to index the array if you intend to operate on the scalar.
(4,629 Views)
This context help entry doesnt help much in understanding your issue.
OK, we see your source is an 1D double array, the sink is a scalar double value. But what are source and sink? Control and Indicator?
I think you best walk throught the initial LV training steps provided as "Getting started".
hope this helps,
Norbert
Norbert
Expert: Geometry
(4,628 Views)
Accepted by stefan57
Go to Help>>Find Examples>> search for array>>open Build Array example.
-In the example they are using integer numeric control.
-If you want array of double type please change data type to double instead of I32.
uday
(4,604 Views)
Pleas post your VI so we can see what you've done.  Then we can offer helpful suggestions.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
(4,581 Views)
Hi udka thanks,
It is workign now.
(4,544 Views)
