cursor move events passing data to dialog
I have a graph where the user moves the cursor and then I pop up an easy to read dialog with the test number and test description in it.  I tried it with a regular dialog with reentrancy but it locks things up.  Is there a better way to do this?
(2,908 Views)
Hello id,
I'm not following your question. could you post a sample of your code that exhibits the behavior you are experiencing?
-N
Staff Certification Engineer
(2,874 Views)
Here it is.  A simple cursor move event calling a dialog and passing updates to it as the cursor gets moved.
(2,849 Views)
Hi id,
It looks like you're wiring a bundle into a bundle control, and not updating the button dialog anywhere in that code.
You need to wire data into a control and then display it on an indicator. You should also do this inside the while loop, so that it continually updates.
-N
(2,844 Views)
I do not comprehend what you are saying about wiring into a bundle.  My event cases bundle/unbundle clusters in them.
I would use just an indicator but my indicator is too big and it would cover the graph so I want a user movable window with the indicator and not just a fixed front panel one.
Could you please clarify what you are saying?
(2,839 Views)
Hi Id,
I have made a quick example of how to have another window display data to a user using queues. Please let me know if this helps.
-N
(2,824 Views)
