10-14-2009 02:09 PM
we have a package that has vi's in it. the vi's are being installed under instr.lib. i have edited the palette with different text and custom icons. this has created dir.mnu files. we distribute these files. things are good.
problem is, we use the version number in the directory name in the path. so for the next version, the path name will be a little different and the icons/buttons on the palette get whacked. only work around i know is to recreate the dir.mnu files.
any ideas?
10-14-2009 02:57 PM
10-14-2009 03:01 PM
10-14-2009 03:02 PM
You could try to 'stamp' the mnu file. I didn't try, but there is some plain text inside that file in 7.1 and maybe it's even xml in 2009. It's dirty and cheap solution.
Felix
10-14-2009 03:08 PM
