delay value
@IDILIO wrote:
See attached Example.vi
OK, now we have a little bit more information. Apparently, you data is generated at a rate of 1000Hz (one sample per millisecond). In order to keep a history for 10 seconds, you need to keep a FIFO buffer of 10000 points in a shift register. whenever you add a new point, you overwrite the oldest.
(Your original question was very ambiguous. We did not even know if the data was acquired at a regular rate).
Message 11 of 16
(1,071 Views)
Ok. Thank you.
As I suspect there is no easy way to do it...
I know my original question was ambiguous...I want a generic "function" that works for all situations...Smiley Tongue
Message 12 of 16
(1,058 Views)
Accepted by IDILIO
Try something like this (attached VI is in LabVIEW 8.2):
Message 13 of 16
(1,057 Views)
Perfect! Thank You!
Message 14 of 16
(1,035 Views)
Good to know about the soultion.
Was not in a position to check the post.
In case an alternative way is required. Find the attached vi saved for version 8.2.
K.Narayanan
Message 15 of 16
(1,016 Views)
Thanks NaruF1
Message 16 of 16
(1,010 Views)
