delete duplicated consecutive elements in array
Hi
I am trying to make a vi that  will get an array and check for each 2 consecutive elements if they are the same - if yes delete only one of them and move on to the next couple and check again.
for example :
 input array :           16 2 67 128 10 10 42 55 10 10 10 10 22 33 10 03 22 55
output  should be  : 16 2 67 128 10  42 55 10  10  22 33 10 03 22 55
i will appreciate  any help
thanks
Message 1 of 11
(3,395 Views)
See here
Ben
Message 2 of 11
(3,389 Views)
Thanks but it is not what i need
the input is:                                  1626 7128 1010 4255 1010 1010 2233 1003 2255
the output from this function is :  1626 7128 1042 5522 3303
and i need it to be :                      1626 7128 10 4255 10 10 2233 1003 2255
from every  duplicated couple to take one
thanks
Message 3 of 11
(3,371 Views)
A simple FOR loop with a conditional output tunnel and a Feedback Node (or shift register) will do the trick.
GCentral
Message 4 of 11
(3,357 Views)
Thanks to you
but still not exactly what  I need because if I have Input 01 10 10 10 10 02
I get out put :        01 10 02
And I want to get                                                              01 10  10  02
from every two consecutive numbers to get  one
(I know if it will be duplicated it would be an even number of times)
Message 5 of 11
(3,346 Views)
Hi nuvo,
so you want to keep a value
 IF x[n] <> x[n-1] OR x[n-1] == x[n-2]
(Well, my expression is most probably not correct, but it's your task to define your requirement anyway. 🙂 )
All you need to do is to define your requirement in the correct way…
Message 6 of 11
(3,338 Views)
This is one of many ways to accomplish what you need. Assuming that the input array has always an even number of elements.
Paolo
Message 7 of 11
(3,337 Views)
Accepted by nuvo
Then just add a little more logic to keep an element if the previous was thrown out.
GCentral
Message 8 of 11
(3,329 Views)
Ditto that!
Quoting myself;
"The first step in solving a problem is clearly defining what the problem is."
Ben
Message 9 of 11
(3,310 Views)
Hey,
What the use of that NaN at the input of Feedback initializer.
Message 10 of 11
(252 Views)
