devcon not recognized
I have recently installed devcon.exe in the following folder: C:\Windows\System32 and it works fine for me when using the command prompt (cmd.exe). However when I try to use it with labview through the "System Exec.vi", I get the following error:
'devcon' is not recognized as an internal or external command,
operable program or batch file.
This seems like the devcon.exe can't be found by Labview. I tried locating the devcon.exe in the same folder as the VI that was running but to no avail. I have attached the code. Any help appreciated.
(15,938 Views)
Accepted by SMcS12
Problem solved. The working directory needs to be left blank and it works then.
(15,936 Views)
How do you fix it? I tried the same thing but it does not work.
(13,271 Views)
