differences in DAQmx Trigger (VI)
for the DAQmx Timing VI in sample clock mode
 task in = passed through from DAQmx Create Virtual Channel VI
 samples per channel = 1000
 sampling mode = finite samples (10178)
 sampling rate = 1000
 error in = passed through from DAQmx Create Virtual Channel VI
no other inputs!
no error produced in this VI
for the DAQmx Trigger VI in any of the following modes
 - start digital edge
 - reference digital edge
 - start analog edge
 - reference analog edge
 edge = rising (10280)
 source for digital = PFI0
 source for analog = AI0
 trigger level = 2.5
 pre-trigger samples = 10
no errors produced in this VI
DAQmx Read VI in Analog Wfm 1 Chan NSamp mode
 timeout = -1
no other inputs!
this VI produces error -200278.  Cannot use continueous (10123) samples in DAQmx Timing VI.
Trigger signal is always analog even when inputted into a digital channel.  Signal may look like a digital signal even though is comes from an analog source.  I don't understand what I'm doing wrong.
Message 11 of 11
(236 Views)
