08-22-2009 11:08 AM
Image of Tim's code.
Ben
05-11-2010 06:16 AM
I would like to change tab name color. I've tried a lot of things but I can't do it.
Which parameters should I use?
thanks
05-11-2010 07:33 AM - edited 05-11-2010 07:35 AM
Its a similar set of property nodes, you can also show and hide the tabs... see the attached vi.
Edit: Sorry - I just reread your post. You want to change the tab name colour, not the tab name. My attachment won't do that, but I'll leave it here anyway in case it helps someone else.
Cheers
Ian
05-11-2010 07:56 AM
I thougth that i was similar but it doesn't seems so easy.
I'd like to displays the name of each tab in color!
05-11-2010 08:13 AM
julesjay wrote:I thougth that i was similar but it doesn't seems so easy.
All is not lost (yet) !
In this thread I posted how to add custom graphics to the tab. With the right graphics you get close.
Ben
05-11-2010 09:01 AM
The above images shows a quick import of images to the tabs. More exotic images would look better and I don't know how to change the images at run time.
Ben
