disabling the ront panel
Hi guys, is there a way to disable a front panel, like how you can disable a control?
I want to freeze some of my VI's say, after 5 minutes of inactivity.
Tyhanks inadvance for the help!!
(2,628 Views)
(2,625 Views)
Can you get away with simply using Set Busy.vi to disable the cursor & keyboard?
Jim
(2,604 Views)
Say that you freezed the VI, then how will you unfreeze them?
What exactly are you trying to do?
Setting the mouse/keyboard busy is a good option..
Guru
Guru (CLA)
(2,594 Views)
Another option is to use a modal popup, like a logout.
I do this in state machine architectures when user login is required, when the system has been idle for too long goto the login state, in this state I hide the FP and popup a modal login screen.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,576 Views)
Yet another way is to use a large, transparent button over the controls you want to disable, and set this to Visible with a property node to lock out users. This doesn't lock out hotkeys, however.
Richard
(2,568 Views)
