displaying info during a cursor move
Hi I am trying to design a popup panel that has parameters calculated from a user moving a cursor on an XY graph.  The popup panel is necessary due to teh amount of screen size that it takes to display the data based on the cursor position.  I have tried many options from subpanels to regular VI panels popping up based on a cursor move event but I get memory crashes and slow operation issues.  Anybody know how to do this to optimize speed of display and memory?  Atatched are my simplified VIs to show what I am trying to accomplish.
Message 1 of 12
(3,361 Views)
Hi id
I came up with a quick solution of displaying the information of the x and y on another front panel by using the event handler VI as a sub VI. This panel however does not popup and I'm not sure as to how fast this is. Do you want the graph panel to be covered up by the pop up window, or do you still want to be able to move the cursor?
I hop the code I added gives you some ideas and post back if this isn't what you were looking for.
Dan
Daniel Harryman MEng
CLA, CPI
Message 2 of 12
(3,336 Views)
Thanks.  I want the graph cursor to be able to be moved while continuous updates are viewed on the popup panel
Message 3 of 12
(3,330 Views)
The problem is that the popup panel grabs the focus. There are probably ways around this, but I am not familiar.
Alternative solutions would be to show the current value in the cursor name or to have a temporary indicator that only shows if the cursor is moved. (see attached, LabVIEW 2012)
Message 4 of 12
(3,327 Views)
I have done this exact same thing in the past.  I used a subVI which was simply the display that I wanted.  I manually opened (and closed) and repositioned the window to be in the corner opposite the direction of the mouse move.  Additionally, for extra flair, I updated the plot images property with a rectangle showing the drag area.
I have attached a very quick and dirty example
(I haven't been able to look at any of the other code, so I hope I'm not too far off the objective here)
Tim Elsey
Certified LabVIEW Architect
Message 5 of 12
(3,310 Views)
I cannot download your example...can you post a snippet for me to see please?
Message 6 of 12
(3,294 Views)
Whuch example are you referring to, and what kind of problems do you have with downloading?
Message 7 of 12
(3,292 Views)
You are showing a chart, which does not have cursors. Substituting a graph shows the same problem when moving the cursor. The popup grabs the focus.
Message 8 of 12
(3,290 Views)
Oh, that kind of cursor.  I was reading this thread thinking mouse cursor.
Changing the Window Appearance->Window Behavior to Floating seems to make it not steal focus.
Tim Elsey
Message 9 of 12
(3,285 Views)
 Are you sure? That is already his setting and it steals the focus.
Message 10 of 12
(3,274 Views)
