.dll file only included if referenced not all the time
As stated above, Windows 10, LabVIEW 2021 SP1 64-bit was used for creation.
Message 11 of 26
(955 Views)
As a note to other readers, Windows 11 does not come with the two .dll files listed
Are you sure?
https://www.thewindowsclub.com/fix-kernel32-dll-errors-in-windows-10
George Zou
Message 12 of 26
(952 Views)
It did not come with the brand new Windows 11 system we have. Nor did it come through a patch or update since.
It is also a common problem based on my google searches. I need my program to install the .dll files if they are not installed regardless due to the final purpose of this program.
Message 13 of 26
(949 Views)
I have gone through the computer extensively and none of these .dll files are present in any manner. Hidden files, locked files, etc... were all checked.
Message 14 of 26
(942 Views)
Those 2 dlls are essential to Windows.  It's hard to believe they are not exist.
They are on my brand new Windows 11.
George Zou
Message 15 of 26
(935 Views)
Good for you! Your lucky!
That is the operating system the program will need to run on per company protocol. Several programs install the missing .dll files, but each distribution of this program will be on a fresh image.
If you have any ideas how to install the .dll files using the LabVIEW distribution please let me know. Unfortunately, other solutions such as directly installing the windows .dll files are not available for me to try at this time.
Message 16 of 26
(932 Views)
yes, I found this. I cannot do this on the company computer. None the less, this does not solve the .dll issues for the NI files.
Message 18 of 26
(920 Views)
Do you get an error for NI dll not found?
Which Vision toolkit did you installed?
George Zou
Message 19 of 26
(909 Views)
No error notifications of any sort.
On Windows 11, I get a pop-up window asking me to find the .dll files. In windows 10, I have zero problems with the program. No NI software was installed on the Windows 11 computer, so it is completely uncontaminated.
I am running Vision Assistant 2021 64 bit.
Message 20 of 26
(905 Views)
