does DAQmx for Linux work with LabVIEW 2009
Will the DAQmx drivers work with Linux LabVIEW 2009?
I have seen some documentation that implies only "version 8.0", other pages that say "8.0 and above"
Which is it?
Thank you, Christopher
(2,386 Views)
According to this table, DAQmx 8.0.1 is supported. Note that table is for PCI devices. The main page has links for other device types.
(2,375 Views)
It won't install into the LabVIEW 2009 directory since the installer for 8.0.1 was written between LabVIEW 8.6 and 2009.
However, if you look at the file list for one of the LabVIEW support RPMs, you'll see which files need to go into the LabVIEW 2009 hierarchy. Also, we haven't tested this, so be sure to rigorously test your setup before deploying 😉
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(2,368 Views)
