duplicate borders
I want to duplicate all the borders of my 2d array a few times so I get a coppy of all outside rows and cols next to them.
Example:
Original:    1     2    3    4
(4-4)          5     6    7    8
                9    10   11  12
                13  14   15  16
Output:    1     1      2       3     4     4
6-6          1     1      2       3     4     4
               5     5      6       7     8    8
               9     9     10     11    12   12
              13   13     14    15    16   16
              13   13     14    15    16   16
(In the middle of the output array you find the origingal array)
I need to get up to 6 kopies of the borders.
So 6 kopie col than the original array and again 6 kopie col.
Same for the rows.
(example has 1 kopie col than the original array and again 1 kopie col.)
Message 1 of 10
(3,040 Views)
Hi
A partial solution may be as shown below
Message 2 of 10
(3,024 Views)
There are many ways obviously, this is slightly long winded. But will do the job.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 3 of 10
(3,019 Views)
Indeed this does the job as in the example.
But I have a 2d array whit random numers as input.
I don't know what the value of the element will be.
What makes it a lot more difficult...
It also can be this:
Original:    10      23    133    44
(4-4)          58     16     37     80
                999    10    131    72
                13      54    50      56
Output:
(6-6)         10    10    23    133    44   44
                10    10    23    133   44    44
                58    58    16     37    80    80
                999  999  10     131   72    72
                13    13    54     50    56    56
                13    13    54     50    56    56
Message 4 of 10
(2,995 Views)
The code I posted will still work for random numbers.
Message 5 of 10
(2,993 Views)
I'm thinking it looks like recursion, but I made this instead:
Note - the little For loops were the beginnings of a recursive solution that would work for 2D and 1D arrays.  I had Matrix and Array size and decrement primitives.
Jim
Message 6 of 10
(2,992 Views)
Thanks for you help guy (.aCe.,jcarmody )!
Both solutions work out!
Message 7 of 10
(2,976 Views)
Accepted by koekie
Same for the rows.
Is this what you're looking for?
Jim
Message 8 of 10
(2,972 Views)
Yes indeed, that was what I need! 🙂
Message 9 of 10
(2,958 Views)
I'm curious about why you need this.  What's it for?
Jim
Message 10 of 10
(2,931 Views)
