08-24-2008 11:43 PM
Is it possible to zoom dynamically(ie. through LabVIEW code) in a graph?
Raja
08-24-2008 11:52 PM
Hi Raja,
yes it´s possible. You can use property nodes of the graph to set the range of the scale. Select the active scale first and set the minimum and maximum value afterwards.
Mike
08-25-2008 12:41 AM
Hi Mike,
Thank you for your reply.
Is it possible to customize Graph Palette to show only X-scale Zoom option alone and make all other tools invisible in Graph Palette ?
Raja
08-25-2008 02:23 AM
Hi raja,
U can right click and choose visible items and select what is required alone.For x-scaling range u can use a property node
