11-25-2013 04:28 AM
If this property is avialable in LV 7
11-25-2013 04:33 AM
Hi, gigi85,
Multicolumn list box also has some thing similar, but its Top Left visible parameter.
Just create new vi and try the same using property nodes and try posting vi.
In the front panel, did u enable the vertical scrollbar (just checking, still it shouldn't be a problem u shud see the property node in block diagram)
I see from KC's post, that even 7.1 has that property( was doubting untill, whether 7.1 had that or not)
11-25-2013 07:10 AM
thanks to all...with top lef visible cell property box i solved my problem 🙂
