08-19-2014 03:13 AM
Hi
I think I am missing some thing simple but cant work it out!
I am trying to create a file. I have simply wired a path to a file that doesnt exist yet in to a open/create/replace file vi and it keeps giving me error 7 even though I have told it to create the file. Any suggestions?
Labvie 11.0.1f2 (32bit)
08-19-2014 03:15 AM
Solved
You need to make sure all the folders in the path are created first!
08-20-2014 10:24 AM
@shavecp wrote:
Solved
In these cases I generally use the OpenG function "Create Dir If Non-Exist" which will make folders recursivly if they don't exist. So if I want to make C:\blah\test\what and there doesn't even exist a C:\blah, then that function will make all of the folders needed. If the folders already exist it does nothing.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
