error code 1181 OPC on CRIO
When I run the OPC code on the CRIO i get error code 1181
Error 1181 occurred at DataSocket Open in [RT] Main Advanced Updated.vi
Possible reason(s):
LabVIEW: Protocol not recognized by LabVIEW.
What Am I missing?
It runs fine (the same code) on the PC side... just not on the CRIO.
Here is a screen shot of code / error
Thanks!
(2,868 Views)
Since the code runs on the PC side and not the cRIO, confirm that Datasocket support for LabVIEW Real-Time is installed on the cRIO. I do not think this is installed by default so make sure the Protocols and Buses»DataSocket for LabVIEW Real-Time box is checked on the software installation wizard for the cRIO. Let us know if this helps.
Best Regards,
Bill
Bill E. | Applications Engineer | National Instruments
(2,839 Views)
I have the same issue, i have installed the datasocket support on the cRIO but it did not change anything.
Hope you can help me, Regards!
(2,732 Views)
Hi eggo4289,
This thread is a year and a half old!  Feel free to create a new one with your issue.
Julian R.
(2,717 Views)
