01-21-2010 01:26 AM
This is a continuation from an old post...
Lets begin with the original problem:
I used to have LV8.5 and vista and never had these problems; now I am using LV2009 and win7
When using the write measurment file express vi I used to get error 1 + NI-488.
I took care of error NI 488 by unistalling the 488 drivers.
Error 1 still persist, but wiring an output error cluster helps so the VI doesn't stop/exit.
And after playing with permission and stuff, I realize the following:
-If I click ENABLE it will stop but after if I click again to re-ENABLE it it will give the error (picture above) and it will say NO PATH.
-if I write a FILENAME while the error is showing and the ENABLE buttons is ENABLE, it will create the file and continue recording.
-I don't get this problem if I used .tdm or .tdms
what make me think that thies express vi can not write/create n its own unless is forced by giving it a new name.
So, nay ideas of what is going on here?
01-21-2010 01:30 AM
The Write to Measurement File Express VI cannot be set to "Save to series of files"
Workaround: Convert the Express VI to a standard subVI
by selecting 'Open Front Panel' using the right-click menu for the
Write to Measurement File Express VI. In the generated SubVI, set the
'new_file' input/control to be True.
Reported Version: 2009 32-bit | Resolved Version: N/A | Added: 07/31/2009 |
01-21-2010 12:56 PM
Thank for the help, but I now get this error message:
Untitled 1.vi:1->test.vi
<APPEND>
<Not A Path>
By the way, I am now using the option "Save to series of files", I am using "Use next available file name; I don't know if this makes a difference.
01-21-2010 04:00 PM
Hi Roddy,
Instead of changing the New File input to True, change the "multi_file" input to true. Does that work?
01-21-2010 04:21 PM
A message thread dealing with this issue.
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=452287#M452287
01-25-2010 06:43 AM
01-25-2010 10:57 AM
I actually the problem by my own. After, I tried everything that I was suggested, I just did the most simple things that I could think off.
My solution: I just copied the express output folder from a labview LV8.5 to my LV200 and somehow it worked just like a charm...
If somebody else need the files, I am glad to send them...
03-04-2010 03:51 AM
I have had a similar problem. Posted under "Labview 9.0: Error 1 occurred at Write To Measurement File"
I tried your trick of copying the express output folder from my labview 8.5.1 into labview 2009 and now the problem has vanished 🙂
However, is there a bug in 2009 then?
03-04-2010 08:05 PM
It's bug in LabVIEW 2009. CAR# 192290.
A workaround is to use a case structure to switch between Enable or not.
Mavis
06-20-2010 12:36 AM
Well I know this is centuries old, but now I'm having the same problem. Would you mind sharing the Express VI from Labview 8.5? I'd appreciate it alot!
