error using write mesaurment file express
You really can't share express VI's from earlier versions.  They really aren't VI's.  They are kind of dynamic creatures that will rewrite themselves every time you go in and modify the properties by way fo the pop up dialog box.  So it will probably break itself again if you touch it in the newer version of LV.
Why don't you go through the tips that are in the other thread?
Message 11 of 12
(548 Views)
Would you please send me a copy of that? Thank you so much.
Message 12 of 12
(463 Views)
