evaluation code for labview 2011
from where i can get lv 2011 evaluation code
(3,340 Views)
What is your requirement ?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,317 Views)
I think if you don't use an activation code, LabVIEW will be in evaluation mode. There is no evaluation code.
(3,312 Views)
The code will same when either evaluation mode or activated. Like I said what is your requirement ?
--Ranjeet
(3,308 Views)
We first need to know what he means with the word "code".
A: Code: The secret letters needed to activate LabVIEW.
B: Code: The diagrams of a program written in LabVIEW.
(3,288 Views)
i require code A :).. actually i did not give the activation code and now i always get a notification that lv will expire after 30 days and now only 5 days are left. whenever i open the lv a window appears to ask question that is . evaluate lv?
and when i clik on it , it ask to enter evaluation code
(3,280 Views)
Well, the evaluation mode is time limited and does not need any codes.
It is possible that under certain circumstances NI can extend the evaluation period for you by giving you a special code. (This is just a wild guess!)  Try to contact your local NI sales rep to see what can be done.
(3,278 Views)
